Summer brings sticky skin, sun tanning, and breakouts. One age-old remedy that’s stood the test of time is the Multani Mitti (Fuller’s Earth) face pack. When combined with rose water, it becomes a powerful skin soother that cools the skin, removes dirt and oil, and restores natural glow – all without chemicals.
🌿 Benefits of Multani Mitti in Summer
- Removes Excess Oil: Absorbs oil from the skin’s surface
- Soothes Sunburn & Tanning: Cools down heat-affected areas
- Fights Acne: Cleans clogged pores and prevents breakouts
- Cooling Effect: Rose water adds a calming, hydrating touch
- Natural Glow: Enhances skin tone without harsh ingredients
🧴 How to Make This Simple DIY Face Pack
Ingredients
- 2 tablespoons Multani Mitti
- 1.5 tablespoons rose water
- 1 teaspoon aloe vera gel (optional – for dry skin)
Steps
- Mix Multani Mitti and rose water in a clean bowl.
- Add aloe vera gel if you have dry or sensitive skin.
- Mix well into a smooth, medium-thick paste.
- Apply evenly on the face and neck.
- Let it sit for 15 minutes (do not overdry).
- Rinse off with cool water.
💡 Tip: Do not let the pack crack or feel overly tight. Wash off while slightly damp for best results.
🕒 When & How Often to Use
- Use 2–3 times a week during summer
- Apply in the evening or after sun exposure
- Always clean your face before applying the pack
🧘�♀� Ayurvedic Perspective
In Ayurveda, Multani Mitti (also called Mrattika) is known for its Pitta-balancing properties, helping calm the body’s heat and inflammation. Rose water is recognized for its soothing effect on the skin and mind, promoting a sense of inner calm and balance.
If you’re looking for a natural, affordable, and chemical-free way to beat oily skin and summer heat, the Multani Mitti and Rose Water face pack is your perfect companion. Add it to your weekly skincare routine and enjoy refreshed, glowing skin – the Ayurvedic way!
